Author Topic: SDR (Software Defined Radio)  (Read 7206 times)
  • Guest
« on: August 06, 2019, 11:12:09 AM »
Software defined radio (aka SDR), is a way of automating tuning into Audio/Digital radio receptions.
I am using a very simple (un-nervingly sensitive) USB dongle type RTL-SDR.COM
(cost inclusive antenna & mount was < £25).
This is able to tune through a huge spectrum of frequencies 0hz!! > 2.5Ghz
On a basic level it will tune into music radio station.....how ever where is the fun in that......
Also covers all the Radio Amateur bands , Dab radio and also Dab TV....etcetera
I am currently using a neat software package called SDR# (SDR Sharp), below gives an idea for what control you have over the RF goodness. (right view image for closer look).
The above Gui is tuned into the FM Broadcast band spectrum analyzer style, the colour frequency bands beneath it shows a running time graph of the signal levels, its useful when you are searching/tuning into data signals which just blip their short data packets sporadically (make it easier to home in on the signal).
I have been experimenting with tracking aircraft and can recommend RTL1090 by jetvision.de for simple quick data.
If you want a more portable system, its possible to connect the  SDR dongle to an Android device (via OTG connector/cable) .
So far my best recommendation is Avare ADB ,  when running, the receiver picks up the Planes Transponder data, giving various metric's of the flight.
Below you can see the airspace in my locality , this was just a quick test with buildings all around, as you can see it will detect aircraft up to 80kms.
(luckily for me Zurich, Friedrichshaven and Altenrhein airports are all within range .. \ü/ .. ).
Its also possible to pick up the International Space Station and also Weather Satellites, however that will take a bit longer for me to achieve.
The advantage of the RF SDF dongle is that its portable, i.e. no need for internet connections, un-tethers you from the Sky-Net . (some 4G bands are in range of this device, however 5G bands might be safe for a bit at least).
I have already a space for it in my "Zombie Apocalypse" rucksack, buy one today before they are outlawed (thats a serious prediction by me ;-)
fritsl
    • TIXITAXI
Re: SDR (Software Defined Radio)
« Reply #1 on: August 09, 2019, 09:54:11 AM »
Very sweet, Gareth!
What would you have to do / would it be possible to tune into the Very Low Frequency bands? (like maybe 50-1000 or so)
  • Guest
« Reply #2 on: August 14, 2019, 01:12:21 PM »
Watcha fritsl
 Still early days with experimenting, not even sure if such "ELF" signals are possible with these dongles , to start with I guess we would need a dipole antenna stretching from Switzerland over to your neck of the woods. :o (a lotta wire).
ZeroMax
  • Badass when not suffering from IBS
  • Do you want ants? Because that's how you get ants.
    • DON'T LOOK AT MY ART!
« Reply #3 on: January 31, 2020, 01:54:21 PM »
I miss you guys!
I played with one of these for a while last year.  I wanted to see if I could detect the hydrogen line with a custom built Yagi antenna attached to my telescope.
DROP * FROM* WHERE 1=1
SUDO RM /DEV/
  • Guest
« Reply #4 on: February 02, 2020, 06:15:42 AM »
Miss U2 Hoff  ;)
I hope they develop these devices a bit faster, before they are outlawed....
On a good note parts of Switzerland are starting to revolt over the installation of the "5G" network. Lets hope "5G" collapses.
"1984 Nixie Time" by 1 what
[May 08, 2020, 01:04:18 AM]
2D Side Scroller Cyberpunk themed by Killer Angel
[February 06, 2020, 06:39:40 AM]
A new wing design for model aircraft / drones by OddBot
[February 06, 2020, 04:42:06 AM]
SDR (Software Defined Radio) by Gareth
[February 02, 2020, 06:15:42 AM]
Circuit Math by ZeroMax
[January 31, 2020, 01:50:18 PM]
NanOMeter by Protowrxs
[January 01, 2020, 12:59:44 PM]
Investigating the VL53L0X Laser Rangefinder by erco
[December 30, 2019, 10:45:44 PM]
PS4 Single Handed Controller Deployed (part 7 of 7) by Gareth
[December 30, 2019, 09:52:29 AM]
"D" -Pad Workio just like Magic (Will Merlin stay or Go) (part 6 of 7) by Gareth
[December 30, 2019, 09:51:27 AM]
PS4 Joystick Digitals 4,5,6,7,10 - Analog's Lx,Ly,Rx,Ry Workio (part 5 of 7) by Gareth
[December 30, 2019, 09:50:37 AM]
Menu Workio ! (part 4 of 7) by Gareth
[December 30, 2019, 09:49:49 AM]
L1 trigger design Workio (Hori controller) (part 3 of 7) by Gareth
[December 30, 2019, 09:48:50 AM]
Hori aka PS4 Joystick Mappings (part 2 of 7) by Gareth
[December 30, 2019, 09:47:17 AM]
PS4 Single Left-Handed Controller (part 1 of 7) by Gareth
[December 30, 2019, 09:44:58 AM]
Time of Flight >>> Rounded Corners !!! by BaldwinK
[December 04, 2019, 05:46:08 PM]
Re: "1984 Nixie Time" by 1 what
Re: "1984 Nixie Time" by tomasp
[April 13, 2020, 06:03:28 PM]
Re: 2D Side Scroller Cyberpunk themed by Killer Angel
Re: "1984 Nixie Time" by Gareth
[February 02, 2020, 06:23:01 AM]
Re: SDR (Software Defined Radio) by Gareth
Re: SDR (Software Defined Radio) by ZeroMax
[January 31, 2020, 01:54:21 PM]
Re: "1984 Nixie Time" by ZeroMax
[January 31, 2020, 01:52:29 PM]
Re: 2D Side Scroller Cyberpunk themed by ZeroMax
[January 31, 2020, 01:45:33 PM]
Re: Investigating the VL53L0X Laser Rangefinder by erco
