Author Topic: MKS Gen L 1.0  (Read 176083 times)
Bappi
Re: MKS Gen L 1.0
« Reply #60 on: May 21, 2019, 03:11:45 PM »
ok it doesnt beep but it does make the blue light flash when i turn the dial yes i went back into marlin and removed the // infront of reprap_full etc
have seen that link and cut the slots but i didnt reverse the exp1 - etc as you said i just turned then 180 deg in same ports so will try exp 1 to 2 etc
ok scrap that exp1 to exp1 reversed and same with exp2 and i now have a working screen  :)) :)) :)) :)) :)) :)) :)) :))
« Last Edit: May 21, 2019, 03:16:25 PM by Bappi »
lifes a bitch then u marry one.....
Re: MKS Gen L 1.0
« Reply #61 on: May 21, 2019, 03:27:08 PM »
"ok scrap that exp1 to exp1 reversed and same with exp2 and i now have a working screen "
 CONGRATS happy printing
Bappi
Re: MKS Gen L 1.0
« Reply #62 on: May 21, 2019, 07:22:54 PM »
Thank you so much for your patience couldnt have done it without your help.
Jinx is the master of mks :)
lllloydo
  • l
Re: MKS Gen L 1.0
« Reply #63 on: October 06, 2019, 01:24:26 AM »
So I just recently got a MKS GEN L board to replace my stock HICTOP 3DP-08 board. (I think it was a problem with the thermistor resistors.)
I was able to load the stock firmware. Everything was hooked up properly (I think). Didn't realize I needed separate stepper drivers, as they were integrated in the stock board. But thanks to this forum, I realized I needed some and got some A4988 for X,Y,Z and extruder and hooked them up.
My problem is that X and Y home but Z does not. (Z is dual motor into 1 socket). I can trigger the Z end stop, which allows movement of X and Y. Both Z motors are plugged in as far as I know. When I get a chance, I'm going to try one of the drivers that I know work and see if that makes a difference. I'm also going to try loading Marlin 1.1.9 and see if that changes anything.
Any thoughts would be helpful. I'll update when I get a chance.
Thanks.
Edit: So I swapped one of the known working stepper drivers for the Z axis. It works now! I'm not sure if maybe I didn't have it seated properly or something, but all stepper motors work. We'll see if anything happens when I flash Marlin onto the printer. (Fingers crossed)
« Last Edit: October 06, 2019, 04:48:12 PM by lllloydo »
