Author Topic: home filament extruders  (Read 4738 times)
« on: April 04, 2017, 07:44:34 AM »
 just feeding my craze!  with this grab & paste run down of home extruders, there no shortage of choices with deep pockets in some cases, for the ready to work out the box.        From the US to Italia with all in one solutions to smart control  with latest generation  machine. no idea if they're any good!! but when I find a trusty review I,ll add it. and  to be honest if i had 7 grand I cruise the med for a month.
 technically the filastruder shouldn't be in the listing  as it a kit based product, but it be a lonely posting on kit form with only the filastruder and the  https://en.wikipedia.org/wiki/Lyman_filament_extruder lyman DIY approach  so in no particular order.
filafab 100:
     "FilaFab PRO 100 – The Filament Fabricator
          FilaFab PRO 100 gives you the power to extrude filament on demand and makes the perfect addition to any FFF 3D printer for hobbyists, students, and professionals alike.
Extrude various colours and diameters as well as experiment with new materials.
Quickly produce the filament you need, when you need it.
Save up to 90% on the cost of ready made filament."
        nabbed from filafab.
· Powerful Motor Drive
· Dedicated Electronics
· Digital PID Temperature Control
· Non Slip Rubber Feet
· Robust All-Metal Construction
· Sleek Low Profile Design
· Integrated Hopper
· Emergency Stop
· Powder Coated Steel Enclosure
· Nozzle Guard
· Auger Guard
· Safe Non Latching Controls
· Interchangeable Nozzles 1.75mm, 3mm & “1mm blanks”
· Replaceable Parts
· Supplied with Everything Required (UK, AUS, US or EU plug)
·Full Range Power Input 120VAC to 220VAC
£800.00  "a £1000 with taxes
filabot Original:
        " The Filabot Original is designed and engineered to bring industrial filament production quality right to your desktop. In fact, you’ll enjoy savings of up to 90% over commercially purchased filament when you produce your own filament using inexpensive, raw plastic pellets. Save even more by turning failed prints and household waste plastics into filament. Create your own custom filaments with unlimited physical properties. Built, inspected, and tested by our technicians at our Vermont facility in the United States."
                nabbed from filabot
-Custom In-line Nozzle: Custom nozzle tapered to the tip for maximum flow efficiency and filament quality
-Universal Power Input: Available in 110VAC (Domestic) or 220VAC (International)
-Programmable Temperature Controller: Room Temperature up to 450°C
-Extrude Rate: 40 ipm, or .5 lb of filament per hour (4043D PLA @ 1.75 mm)
-Filament Output: 1.75 mm and 2.85 mm; any other size with custom-drilled nozzle
-Extrudable Plastic Types: ABS, PLA, PC, HIPS, and PP
-Material Input Size: Powder to 1/8in pellets. We recommend that you have no less than 1/4lb of material in the hopper.
-Feed Screw Speed: 35 RPM
-Power Draw: ~500 Watts
-Enclosure Size: 18 in by 7 in by 9 in
-Full, 1-Year Warranty
£1000.00 + a bit
Noztec:
  "With retail filament prices being so expensive we identified a need to reduce the cost of plastic for 3D printing and have built a reliable filament extruder for use at home or office. The Noztek Pro combines a high torque planetary motor and a bespoke engineered screw, which offers fast extrusion of ABS ans PLA resin pellets at tight tolerances.  Most of the other extruder’s currently on the market are in kit form, which is great for the enthusiast, but as 3D printers become mainstream we felt that consumers would much rather have a plug and play model. The Noztek Pro can be unboxed and is ready to use in about 15 minutes, just plug in, turn on the heater add the resin pellets, then turn on the motor and you will be extruding straight away."
        nabbed from Noztek
-Converts either a variety of plastic Pellets (ABS, PET, HIPS, PLA ) or powder to either -1.75mm or 3mm filament (Both dies included). Blanks also available.
-Extrudes at 1-300 Celsius
-Bespoke screw design
-Swappable barrel
-Filament tolerances 1.75mm (+ .04/ – .04)
-Fully assembled and ready to make filament right out of the box (not a kit).
-Extrudes at up to 2-2.5m per minute (Depending on extrusion temp and plastic).
-Produces 1kg of filament in 2/3 hours
-Simple to use.
http://www.noztek.com/
£1000.00
strooder:
    "We aim to empower people to have access to bespoke 3D printing solutions from anywhere.
      We want to democratise the production of filament so that the entire creation process is in your hands."
                                  yea nabbed of strooder. may require an email!
does come with touch screen and some kind of space age nozzle coating.
https://omnidynamics.co.uk/
£1000.00
protocycler:
  "The only complete desktop filament recycler. Featuring integrated grinding and spooling, automatic computer control, and full safety certification. Create 3D printing filament sustainably, on demand, for free."
                                                    nabbed
ProtoCycler is the first and only 3D printer filament extruder with:
-Full safety certification, including UL, ULc, RoHS, CE, FCC, etc
-A built in grinder, so you can actually recycle!
-Diameter feedback and computer control, for perfect 3D printer filament in either ABS or PLA
-Automatic and distributed spooling
-Automatic start up and shut down
-Full Manual mode for hacking
-Open source software and community
-Beautiful brushed aluminium enclosure in your choice of raw or black
-Patent pending MixFlow extrusion technology
Tech Specs
-Diameter tolerance: +/- 0.05mm
-Extrusion speed: Up to 10 ft/minute
-Electrical usage: 90 W avg
-Dimensions: 15” x 14” x 9” – 20 kgs
-Grinder input: 4” x 5”
-Hopper Capacity: Expandable
-Max Temp: All metal hot end for most plastics under 260 C
http://www.redetec.com/
$900/£1000.00 with HM taxes.
felfil:
    "Felfil Evo is a safety and easy to use plastic filament extruder, able to produce custom and recycled filament for 3D printers starting from pellet or wrong prints.
The mechanical components are made in Italy and manufactured in durable materials, ensuring product quality; the extrusion screw is in fact specially made. An electonic board compatible with Arduino automates the filament extruder machine and make it customizable.
The aluminum case is very easy to open to allow anyone to work on the internal components in case of need. The essential, compact design makes it suitable for all types of users. A prefect addition to your desktop 3D printer."
  Choose your nozzle diameter (1.75 – 2.85), set manually the correct temperature and gearmotor speed, then start to make high quality custom filament for your 3D printer.
Technical details
Temperature                                    up to 280°
Hopper volume                                        250g
Tolerance                                           +/- 0.07
Extrusion speed                                   150grams/h
https://felfil.com/shop/felfil-evo-assembled/
£1000 after the year 2020!
filastruder:
          "Are you frustrated with the high cost of filament for your 3D printer? Do you desire the ability to produce filament on demand, as it is needed, in the color and size appropriate for your 3D project?
The Filastruder filament extruder meets these needs and more, because it is a filament-making machine. The reason for starting this project is simple - raw plastic pellets are cheap costing only a few dollars per kg, while filament for 3D printers is much more expensive - $30/kg and more. "
                                               nabbed from filastruder
Specifications:
• Extrusion Rate: 12-18 inches/minute with MG94 ABS (3-5 lbs/day)
• Extrusion Temperature: tested with 170-235C (email support for information on higher temps)
• Size: 21”x6”x6”
• Noise: 52dBA @ 3ft
• Power: 110-240VAC,50/60Hz, 75watts peak, 50 watts average
    "The Filastruder is a first-generation, experimental piece of hardware. Treat it as such. It is not a toaster or microwave. Do not leave the house or go to sleep with it running. Be sure to check in on it periodically. Basically, use common sense."
                                                          Tim "filastruder"
£300 +a week in customs! + £66 import vat
                              TO BE CONTINUED
« Last Edit: April 06, 2017, 07:57:30 AM by jinx »
"1984 Nixie Time" by Gareth
