Author Topic: ESP8266 to C# -- WiFi Serial  (Read 10095 times)
Ladvien
  • Alabtu-ian Refugee
« on: March 19, 2017, 09:39:49 AM »
ESPER
ESPER is a mini project to troubleshoot how the Lumi program will interact with a remote device.
There are two sets of code below, the first is the C# side of the interaction.  It sets up an HttpClient with POST and GET calls.  The one real variant which makes C# ESPER code a little bit different is the asynchronous polling POST request for data.  This is meant to imitate a serial communication RX line across a WiFi signal.
The other code is Arduino C and sets up the ESP8266 device as an HTTP WebServer.  It can then take data received from the UART and print it to the server.  This allows the C# polling POST call to pick up the data.  Of course, in the same manner, there is a the Arduino code is setup to receive data from the HTTP Client and transmit it across the UART.  Voila! Serial communication across WiFi.  Now all we need is the annoying autobauding sounds and we will be firmly back in the 1990s.
Update 2/7/2016
I've added a search method to the ESPER class.  Basically, this iterates over a range POSTing a name request for the ESPER.  When the C# code discovers an ESPER, then it adds it to an array.  I'm pretty happy with it.
I did run into an issue trying to use Windows.HttpClient, as there doesn't seem to be a way to adjust the timeout.  The default was like 3 seconds, which is way too long.  Therefore, the System.Net.HttpClient was used, since it has a Timeout property which takes a Timespan.
Windows C# Code
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.Runtime.InteropServices.WindowsRuntime;
using System.Text;
using System.Threading;
using System.Threading.Tasks;
using Windows.Storage.Streams;
using Windows.Web.Http;
namespace ESPER
    class Esper
        const int defaultPollingDelay=50;
        HttpClient httpClient=new HttpClient();
        CancellationTokenSource PollingForDataCancelToken=new CancellationTokenSource();
        private string WebServerUrl { get; set; }
        private int PollingDelay { get; set; }=defaultPollingDelay;
        private bool PollingActive { get; set; }=false;
        public Esper(string consumerUrl)
            WebServerUrl=consumerUrl;
        public async void PostByteArray(byt[/pre]e[] data)
            var httpClient=new HttpClient();
            var webService=WebServerUrl + "data";
            var resourceUri=new Uri(WebServerUrl);
            try
                IBuffer buffer=data.AsBuffer();
                using (HttpBufferContent content=new HttpBufferContent(buffer))
                    content.Headers.Add("Content-Type", "text/html; charset=utf-8");
                    content.Headers.ContentLength=buffer.Length;
                    var response=await httpClient.PostAsync(resourceUri, content);
                    Debug.WriteLine(response);
            catch (TaskCanceledException ex)
                // Handle request being canceled due to timeout.
        public async void PostString(string str)
            var webService=WebServerUrl + "string";
            var resourceUri=new Uri(webService);
            try
                using (HttpStringContent content=new HttpStringContent(str, Windows.Storage.Streams.UnicodeEncoding.Utf8))
                    content.Headers.ContentLength=(ulong)str.Length;
                    using (var response=await httpClient.PostAsync(resourceUri, content)) { };
        public void Start()
            if(false == PollingActive)
                PollingActive=true;
                PollWebServerDataAvailability();
        public void End()
            PollingActive=false;
            PollingForDataCancelToken.Cancel();
        public void SetPollingDelay(int delayInMilliseconds) { PollingDelay=delayInMilliseconds; }
        private void PollWebServerDataAvailability()
            try
                Task.Run(async () =>
                    while (true)
                        if (PollingForDataCancelToken.IsCancellationRequested)
                            PollingForDataCancelToken.Token.ThrowIfCancellationRequested();
                        await GetData();
                        await Task.Delay(PollingDelay);
                }, PollingForDataCancelToken.Token);
            } catch (TaskCanceledException)
                // TODO: Add cancelation callback here.
        public async Task<string> GetData()
            var cts=new CancellationTokenSource();
            cts.CancelAfter(TimeSpan.FromSeconds(30));
            var webService=WebServerUrl + "buffer";
            try
                HttpResponseMessage response=await httpClient.PostAsync(resourceUri, null);
                var message=await response.Content.ReadAsStringAsync();
                if (message != "") { Debug.WriteLine(message); }
                response.Dispose();
                cts.Dispose();
                return message;
                return "";
            return "";
Arduino ESPER​ WebServer
 * This code has been adapted from:
 *    "SDWebServer - Example WebServer with SD Card backend for esp8266
 *    Copyright (c) 2015 Hristo Gochkov. All rights reserved.
 *    This file is part of the ESP8266WebServer library for Arduino environment."
const char* ssid = "SSID";
const char* password = "password";
// Gross.  Global variables.  These are used for collecting Serial Data.
String inputBuffer = "";
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const int ledPin = 2;
const char* host = "esp8266sd";
ESP8266WebServer server(80);
void returnOK() {
  server.send(200, "text/plain", "");
void returnFail(String msg) {
  server.send(500, "text/plain", msg + "\r\n");
void debugWebRequest(){
  String message = "";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    message += " NAME:"+server.argName(i) + "\n VALUE:" + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  Serial.print(message);
void getSerialBuffer(){
  Serial.print("Sent data: ");
  Serial.println(inputBuffer);
  server.send(200, "text/plain", inputBuffer);
  inputBuffer = "";
void handleUnknownPost(){
  returnOK();
  //debugWebRequest();
  Serial.print("Unknown POST.");
void handleStringPost(){
  returnOK();
  Serial.print("Got data: ");
  Serial.print(server.arg(0));
void handleDataPost(){
  returnOK();
  Serial.print("Data POST.");
void handleNotFound(){
  returnOK();
  Serial.print("Resource not found POST.");
void setup(void){
  pinMode(ledPin, OUTPUT);
  Serial.begin(115200);
  Serial.setDebugOutput(true);
  Serial.print("\n");
  WiFi.begin(ssid, password);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  digitalWrite(ledPin, HIGH);
  bool isLedPinOn = true;
  // Wait for connection
  uint8_t i = 0;
  while (WiFi.status() != WL_CONNECTED && i++ < 20) {//wait 10 seconds
    delay(500);
    Serial.print(".");
    isLedPinOn = !isLedPinOn;
  Serial.println("");
  if(i == 21){
    Serial.print("Could not connect to");
    while(1) {
      digitalWrite(ledPin, isLedPinOn ? HIGH : LOW);
      delay(200);
  digitalWrite(ledPin, LOW);
  Serial.print("Connected! IP address: ");
  Serial.println(WiFi.localIP());
  if (MDNS.begin(host)) {
    MDNS.addService("http", "tcp", 80);
    Serial.println("MDNS responder started");
    Serial.print("You can now connect to http://");
    Serial.print(host);
    Serial.println(".local");
  server.on("/", HTTP_POST, handleUnknownPost);
  server.on("/string", HTTP_POST, handleStringPost);
  server.on("/data", HTTP_POST, handleDataPost);
  server.on("/buffer", HTTP_POST, getSerialBuffer);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("HTTP server started");
void loop(void){
  server.handleClient();
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    inputBuffer += inChar;
Re: ESP8266 to C# -- WiFi Serial
« Reply #1 on: March 19, 2017, 01:24:36 PM »
Interesting. Still trying to understand what you have made, how it can be used. Is it a general purpose setup or very specialized for the debugging task you had at hand?
One thing springs in mind, wouldn't a TCP socket have been more ideal for the serial emulation?
Ladvien
« Reply #2 on: March 20, 2017, 08:09:04 AM »
Well, it's not complete yet, but the idea is to have C# framework which can search for ESP8266's on the network and easily pass data between the computer and microcontroller.
Another goal is to have the ability to upload AVR programs wirelessly using the TinySafeBoot bootloader.  I've written several iterations of the TSB uploader.  The last iteration I demonstrated the proof-of-concept using Bluetooth LE.
Wireless Upload to BoB Brain Board (Atmega328P) using BLE
As for the TCP socket; I've no experience at network programming, however, I think you are right.  TCP socket's would make the process much smoother and flexible.  But, the goal was to consume framework / packages to accomplish a task quickly.  The ESP8266's Arduino WebServer made it extremely quick to setup.
This may not seem logical, but I've been reading the The Mythical Man Month and a pitfall outlined is trying to re-write base level code--as it is consumes more time and is prone to error.
