Author Topic: "Standard" test prints for 3D print beginners to test  (Read 10061 times)
« on: March 23, 2016, 05:54:53 PM »
Testing the new 3D printer may be important for beginners like me.
Some of the items were suggested in the shoutbox and I also added some which seem to be interesting:
Euro XY calibration : http://www.thingiverse.com/thing:916214
wicked-small cylinder test: http://www.thingiverse.com/thing:21945
5mm Calibration Cube Steps: http://www.thingiverse.com/thing:24238
More advanced:
#3DBenchy - The jolly 3D printing torture-test : http://www.thingiverse.com/thing:763622
Torture Test: http://www.thingiverse.com/thing:33902
Test your 3D printer! v2 : http://www.thingiverse.com/thing:1019228
« Last Edit: May 31, 2016, 04:49:00 PM by MEgg »
ossipee
  • o
Re: "Standard" test prints for 3D print beginners to test
« Reply #1 on: March 23, 2016, 06:11:33 PM »
Since you have gotten a delta a tip for setting your Z (height) home the printer G28 if using marlin, then from the top bump machine 10mm down counting how many times, (measure that 10mm = 10mm) until close to base, then 1mm steps until you are the thickness of a matchbook cover or less from base that number is your Z.
« Reply #2 on: March 23, 2016, 07:04:28 PM »
hollow cube http://www.thingiverse.com/thing:30171 it help tweaking those retraction setting in your chosen slicer.
« Reply #3 on: March 24, 2016, 06:02:06 AM »
3DBenchy is of course my favorite test print. I use it mainly to try out slicer settings.
To tune retractions settings I've used this: http://www.thingiverse.com/thing:15087
To calibrate X/Y axis I've printed this: http://www.thingiverse.com/thing:28109
« Reply #4 on: April 26, 2016, 06:22:45 PM »
Make: 2015 3D Printer Shoot Out Test Models
http://www.thingiverse.com/thing:533472
ossipee
  • o
« Reply #5 on: April 27, 2016, 05:30:55 PM »
MEgg start small, the prints are faster get close going with small quick prints then when you are getting good, go for larger longer more complex prints, you will save time and not waste plastic. With a delta big diameter circles/objects are very useful for getting your end stop adjustments correct, they just take longer so do them when your close.
« Reply #7 on: August 05, 2016, 06:24:30 PM »
Two other ooze/retraction tests:
http://www.thingiverse.com/thing:22263
http://www.thingiverse.com/thing:909901
Both are small and give "quick" results.
« Reply #8 on: September 28, 2016, 03:25:49 PM »
« Reply #9 on: November 12, 2016, 10:22:07 AM »
cube with a hole!
*cube with hole.stl
« Reply #10 on: April 22, 2017, 05:22:09 PM »
« Reply #11 on: April 29, 2017, 11:15:26 AM »
 delta :
        like this one megg  more so for its summary http://www.thingiverse.com/thing:745523
