Author Topic: Changing PWM frequencies on Arduino controllers  (Read 5553 times)
OddBot
  • Have fun every day!
« on: February 28, 2016, 01:38:13 AM »
By default, most Arduino pwm outputs are set to about 490Hz or 980Hz. These frequencies work quite well with small dc brushed motors but can cause unwanted noise or reduce motor torque in some cases.
The frequencies are generated as a result of the clock frequency (this tutorial assumes 16MHz) being divided by a pre-scaler. For 8Mhz clocks, divide the frequency by 2.  Before you start changing frequencies there are a few things you must be careful of.
  • Many motor controllers cannot work at high frequencies and can short circuit when you change to high frequencies.
  • High frequencies increase inductive reactance of the motor windings. This can increase heat and decrease motor torque.
  • Timers may be used by other functions and libraries. Changing PWM frequencies can have unexpected side affects.
So before you start, check what is the maximum PWM frequency your motor controller can handle, check what timers are currently used (eg. Timer 0 used for Arduino timing functions, Timer 1 or 5 used for servos, Timer 2 used by tone() command.
Below are 2 list of timer settings (I've also attached a text file). 1 for Arduinos using ATmega 8, 168, 328 and the other for Arduino's using ATmega1280 and ATmega2560 processors. Cut and paste the lines you need directly into your setup() function.
You should find that lower frequencies provide better torque for most small DC hobby motors. A frequency of 122.55Hz provides good torque without too much noise. A frequency of 30.64Hz give the best torque at low speeds but can cause noticable vibration in your robot.
Frequencies from 490.2Hz to 7812.5Hz are noisy and cause the motors to loose torque. Frequencies above 20000Hz cannot be heard by most humans although the pets might complain. Unless your motor and motor driver are designed for these frequencies then you risk damaging them. I found that the most small DC motors lost a lot of torque and tended to overheat.
Note: Divide the PWM frequency by 2 for an 8MHz clock, multiply by 1.25 for a 20MHz clock.
For Arduino Uno, Nano, Micro Magician, Mini Driver, Lilly Pad and any other board using ATmega 8, 168 or 328
//---------------------------------------------- Set PWM frequency for D5 & D6 -------------------------------
//TCCR0B = TCCR0B & B11111000 | B00000001;    // set timer 0 divisor to     1 for PWM frequency of 62500.00 Hz
//TCCR0B = TCCR0B & B11111000 | B00000010;    // set timer 0 divisor to     8 for PWM frequency of  7812.50 Hz
  TCCR0B = TCCR0B & B11111000 | B00000011;    // set timer 0 divisor to    64 for PWM frequency of   976.56 Hz
//TCCR0B = TCCR0B & B11111000 | B00000100;    // set timer 0 divisor to   256 for PWM frequency of   244.14 Hz
//TCCR0B = TCCR0B & B11111000 | B00000101;    // set timer 0 divisor to  1024 for PWM frequency of    61.04 Hz
//---------------------------------------------- Set PWM frequency for D9 & D10 ------------------------------
//TCCR1B = TCCR1B & B11111000 | B00000001;    // set timer 1 divisor to     1 for PWM frequency of 31372.55 Hz
//TCCR1B = TCCR1B & B11111000 | B00000010;    // set timer 1 divisor to     8 for PWM frequency of  3921.16 Hz
  TCCR1B = TCCR1B & B11111000 | B00000011;    // set timer 1 divisor to    64 for PWM frequency of   490.20 Hz
//TCCR1B = TCCR1B & B11111000 | B00000100;    // set timer 1 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR1B = TCCR1B & B11111000 | B00000101;    // set timer 1 divisor to  1024 for PWM frequency of    30.64 Hz
//---------------------------------------------- Set PWM frequency for D3 & D11 ------------------------------
//TCCR2B = TCCR2B & B11111000 | B00000001;    // set timer 2 divisor to     1 for PWM frequency of 31372.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000010;    // set timer 2 divisor to     8 for PWM frequency of  3921.16 Hz
//TCCR2B = TCCR2B & B11111000 | B00000011;    // set timer 2 divisor to    32 for PWM frequency of   980.39 Hz
  TCCR2B = TCCR2B & B11111000 | B00000100;    // set timer 2 divisor to    64 for PWM frequency of   490.20 Hz
//TCCR2B = TCCR2B & B11111000 | B00000101;    // set timer 2 divisor to   128 for PWM frequency of   245.10 Hz
//TCCR2B = TCCR2B & B11111000 | B00000110;    // set timer 2 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR2B = TCCR2B & B11111000 | B00000111;    // set timer 2 divisor to  1024 for PWM frequency of    30.64 Hz
For Arduino Mega1280, Mega2560, MegaADK, Spider or any other board using ATmega1280 or ATmega2560
//---------------------------------------------- Set PWM frequency for D4 & D13 ------------------------------
//---------------------------------------------- Set PWM frequency for D11 & D12 -----------------------------
//---------------------------------------------- Set PWM frequency for D2, D3 & D5 ---------------------------
//TCCR3B = TCCR3B & B11111000 | B00000001;    // set timer 3 divisor to     1 for PWM frequency of 31372.55 Hz
//TCCR3B = TCCR3B & B11111000 | B00000010;    // set timer 3 divisor to     8 for PWM frequency of  3921.16 Hz
  TCCR3B = TCCR3B & B11111000 | B00000011;    // set timer 3 divisor to    64 for PWM frequency of   490.20 Hz
//TCCR3B = TCCR3B & B11111000 | B00000100;    // set timer 3 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR3B = TCCR3B & B11111000 | B00000101;    // set timer 3 divisor to  1024 for PWM frequency of    30.64 Hz
//---------------------------------------------- Set PWM frequency for D6, D7 & D8 ---------------------------
//TCCR4B = TCCR4B & B11111000 | B00000001;    // set timer 4 divisor to     1 for PWM frequency of 31372.55 Hz
//TCCR4B = TCCR4B & B11111000 | B00000010;    // set timer 4 divisor to     8 for PWM frequency of  3921.16 Hz
  TCCR4B = TCCR4B & B11111000 | B00000011;    // set timer 4 divisor to    64 for PWM frequency of   490.20 Hz
//TCCR4B = TCCR4B & B11111000 | B00000100;    // set timer 4 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR4B = TCCR4B & B11111000 | B00000101;    // set timer 4 divisor to  1024 for PWM frequency of    30.64 Hz
//---------------------------------------------- Set PWM frequency for D44, D45 & D46 ------------------------
//TCCR5B = TCCR5B & B11111000 | B00000001;    // set timer 5 divisor to     1 for PWM frequency of 31372.55 Hz
//TCCR5B = TCCR5B & B11111000 | B00000010;    // set timer 5 divisor to     8 for PWM frequency of  3921.16 Hz
  TCCR5B = TCCR5B & B11111000 | B00000011;    // set timer 5 divisor to    64 for PWM frequency of   490.20 Hz
//TCCR5B = TCCR5B & B11111000 | B00000100;    // set timer 5 divisor to   256 for PWM frequency of   122.55 Hz
//TCCR5B = TCCR5B & B11111000 | B00000101;    // set timer 5 divisor to  1024 for PWM frequency of    30.64 Hz
Differences in timer frequencies:
You will see that timer 0 frequencies are double that of the other timers. This is because Timer 0 is used by Arduino for timing functions such as delay(), millis(), micros() and more. To get better accuracy, The Arduino IDE sets Timer 0 to fast PWM mode. It should be noted that for these timing functions,the Arduino software automatically compensates for 8MHz, 16MHz and 20MHz clocks. The default prescaler setting is always 64.
For all other timers, the Arduino IDE sets the timer mode to phase correct PWM. This causes the counter to count from 0 to 255 and then from 255 back to 0 again. This provides a more symetrical output but at half the frequency. The default timer settings are configured in the wiring.c file of your Arduino installation.
If you are looking for a timer library for generating timer interrupts or custom PWM outputs then check out this library: http://playground.arduino.cc/Code/Timer1. There are 2 versions, one for timer 1 and another for timer 3. It should be easy to modify these libraries to work with the other timers if required.
If you want more information about configuring timers and the different modes then check these tutorials out.
Ken Shirriff's secrets of Arduino PWMs: http://www.righto.com/2009/07/secrets-of-arduino-pwm.html
RobotFreaks's Arduino 101: Timers and interrupts: http://letsmakerobots.com/node/28278
danphobic_
  • personal text?
Re: Changing PWM frequencies on Arduino controllers
« Reply #1 on: April 12, 2016, 11:36:26 AM »
This is really great stuff! I haven't needed to use it yet, but I almost certainly will be needing it in the future!
"1984 Nixie Time" by Gareth
