Author Topic: Dagu 4 Channel Motor Controller: motor connection wrong way?  (Read 5137 times)
« on: November 20, 2015, 10:24:50 AM »
Hello,
I am using this kit:
http://robosavvy.com/store/dagu-rover-5-arduino-kit-4-motors-and-4-encoders.html
The last one had problems with the encoders so I got a new one.
But when putting things together I had this problem again, that the motor connections are only fitting onto the Dagu 4 Channel in the wrong way:
red wire onto - and black wire onto +:
As far as I can see other people  have the same problem but seem to ignore it:
http://3.bp.blogspot.com/-YEpsKQFLE3s/U3lnNxA5F4I/AAAAAAAACmE/wF59Csblhx4/s1600/motorBoardConnected.jpg
https://www.ez-robot.com/uploads/DaguPhoto-635073171197031250.png
http://letsmakerobots.com/files/field_primary_image/image_6.jpg?
or simply cut the wires and resolder:
http://letsmakerobots.com/node/30878
Last time I did not mind but this time I want to make sure that this is no problem.
Is that ok for the Dagu 5 Rover?
« Last Edit: November 02, 2017, 05:53:54 PM by MEgg »
SixSixSevenSeven
Re: Dagu 4 Channel Motor Controller: motor connection wrong way?
« Reply #1 on: November 20, 2015, 12:39:14 PM »
Consider your basic electronics, motors do not have a + and a - side as such. Run a current one way, they spin in one direction, run a current the other way, they spin in another direction.
« Reply #2 on: November 23, 2015, 05:07:58 PM »
I second 6677's sentiment about motors not having a positive and a negative side.
If you want the motor to spins opposite the way the current spin, you can swap the connectors without cutting the wire. You just need to lift a plastic prong and easy the metal connector out of the housing.
« Reply #3 on: November 27, 2015, 06:48:39 PM »
My fear was, that there is some additional electronics which might need correct + and -.
But everyone says that it does not matter so it is ok and seem to be motor only.
