Author Topic: Arduino and C++ like code  (Read 4286 times)
« on: November 02, 2015, 05:51:16 PM »
I tried to put my code into a more object like manner but when using the
   attachInterrupt();
in my constructor I get all sorts of errors (e.g.: "
cannot convert 'Motor::encodercountHR_intproc' from type 'void (Motor::)()' to type 'void (*)()'  ")
and so on.
Is there a version of    attachInterrupt() which can be used in more object like code?
I also found
http://forum.arduino.cc/index.php?topic=41713.0
but the not so good solution that worked was putting the interrupt function outside of the class and make the variables public and then
do the  attachInterrupt(); in setup() again, which somehow breaks the whole concept.
Re: Arduino and C++ like code
« Reply #1 on: May 04, 2016, 08:54:25 PM »
Arduinos (8 bit AVR micros) are a very poor match for C++.  The C++ libraries aren't even close to fully implemented.  This quesiton in the avr-libc FAQ tells a bit about it. http://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_cplusplus
One of my biggest complaints with arduino is their mixing in of C++.  The processor just isn't big enough to support it properly and it gives people a false impression.
deshipu
  • Radomir Dopieralski
    • Homepage
« Reply #2 on: May 04, 2016, 10:32:24 PM »
Also, I'm pretty sure you cannot use attachInterrupt with class methods. Use regular functions, and call the method from it.
« Reply #3 on: May 05, 2016, 07:39:38 AM »
I am using that half implemented object like strategy now. Pitty that they do not implement it completely. If I get some too slow reaction
I will have to change it again anyway.
