Author Topic: C++ coding question  (Read 2225 times)
fad0
  • f
    • My Robot Blog
C++ coding question
« on: November 01, 2015, 01:31:52 AM »
I just got my Pixy and am in the process of integrating it onto Endeaver, my son's BOE bot.  I am reviewing the code on the Pixy wiki and came across this:
for (i=0, sum=0; i<sizeof(Block)/sizeof(uint16_t); i++)
      if (g_blockType==NORMAL_BLOCK && i>=5) // no angle for normal block
        block->angle = 0;
        break;
      w = getWord();
      sum += w;
      *((uint16_t *)block + i) = w;
Can someone explain
*((uint16_t *)block + i) = w; ?
Thanks.
Fad0
deshipu
  • Radomir Dopieralski
    • Homepage
Re: C++ coding question
« Reply #1 on: November 01, 2015, 05:24:49 AM »
Let's do it step by step:
(uint16_t *)block
This means "treat the variable 'block' as if it was of type 'uint16_t *'", where "uint16_t *" means "a pointer to uint16_t".
Incrementing a pointer to a certain type moves it by the size of the type being pointed to in memory. So this means "make a pointer that points i * 2 bytes further" (16 bits = 2 bytes).
And finally:
This is pointer dereference, so it says "take whatever the pointer is pointing to".
In summary, the whole line could be possibly written as:
((uint16_t *)block)[i] = w;
fad0
  • f
    • My Robot Blog
« Reply #2 on: November 01, 2015, 07:18:18 AM »
Very clear explanation. Thanks deshipu!
