Author Topic: Time of Flight >>> Rounded Corners !!!  (Read 2031 times)
« on: November 07, 2018, 03:46:01 AM »
I placed the Sensor rig into a cardboard box just to get a feeling for the data.
This is two passes of the probe, so you can see the slight variance in data.
Overlaying the raw data for 180°.... this was with GIMP so its just approximate
all looks kinda good except Hmmmm.... rounded corners cannot be explained...
another scan with DVD's :-
maelh
  • m
Re: Time of Flight >>> Rounded Corners !!!
« Reply #1 on: November 11, 2018, 05:25:15 AM »
I am also looking to use this sensor, so I wonder what causes the rounded corner. From what I remember it has a limited resolution when things are close by, it might be caused by that.
« Reply #2 on: November 12, 2018, 01:01:49 PM »
How fast does this turn?
What happens if you turn slower (if possible at all)?
« Reply #3 on: November 13, 2018, 03:45:41 AM »
I have experimented and there is no difference by slowing it down. (My mind is boggling how it can measure the time it takes for light to travel 5cm)
From the specs the measurement acquisition time is around 40ms ... my current scan rate for 360° is 3 seconds.
« Reply #4 on: November 13, 2018, 03:53:46 AM »
The sensors is darn amazing if you ask me.... there are many hidden register codes which allow you to tune it to your way of using it..
At the moment I am still none the wiser with regards to the rounding.
one guess is that it is picking up reflections (after all it is a IR laser) so a lot of scattering of light is possible, it has good resistance to ambient light (compared to the Sharp sensors (anyone still use them?)).
Another guess is the the laser is TXed in a looooong cone shape and also the received detector receives as a cone. (this does not help I am speculating with my first guess above).
« Reply #5 on: November 13, 2018, 04:07:31 AM »
By the Way the Module will pick up a 3mm vertical BBQ stick at distance, not many sensors have this capability  ???
« Reply #6 on: November 14, 2018, 05:57:24 PM »
Shouldn't that mean that for each 1° of the 360° you need at least 40ms, which is
40ms * 360° ->  14.4s ?
If it is possible to scan per 1°.
« Last Edit: November 14, 2018, 06:03:29 PM by MEgg »
« Reply #7 on: November 14, 2018, 06:26:08 PM »
Also from the central position of sensor S:
from the sensor S to the edge of the front line of the cuboid from my understanding
the beam 1 would be > beam 2 > beam 3 < beam4
and so on, if it goes straight.
Just a simplification but I guess this draws a curve over 1,2,3,4
I guess the cone shape you are talking about gives a bit uncertainty also
which seems to be quite narrow from your data.
The distance should be a line if you drive the sensor from left to right in the same distance.
I think this would be the same with all central stationary ToF sensors, which rotate but do not move from left to right in this case.
« Reply #8 on: November 15, 2018, 03:13:11 PM »
Here are the specs for the TOF showing the cones detect/emit (which I think contributes to the miss detect)
« Reply #9 on: November 15, 2018, 03:21:51 PM »
ahha... I should explain that the stepper is cheating at the moment meaning 360°=400 steps of the stepper.... and I am operating 2 sensors at same time, one for front 180° and second for back 180°.
Indeed yes when the stepper is placed into 1/16 step mode.... which means 360°= 6400 steps so you can achieve quite a resolution (at the expense of speed)
Re: Meowth Abandoned by Nemesis
Meowth Abandoned by BaldwinK
[April 10, 2019, 06:35:48 AM]
Re: Bench Power: Help a rebel out by jinx
Bench Power: Help a rebel out by ZeroMax
[March 27, 2019, 10:00:53 PM]
