Author Topic: syncthing - true p2p directory sync  (Read 1701 times)
« on: January 18, 2018, 03:21:49 PM »
Recently I discovered syncthing - a p2p directory sync. You find it over here
Syncthing is true peer-to-peer, data never gets stored on central server out of your control.  See it as Dropbox, but without the servers. The peer machines are the servers! They form the network. (if you let them)
Basically all it does is to keep a directory synchronized between two or more machines, save a file one peer, read it moments later on a different peer. A peer can have multiple directories, shared with different peers, one for family photo album, an other for files shared between work and home and so on.
In syncthing use the term Device which actually means user@host. So every one of my machines, 7 so far, I have installed syncthing on my user account, most linux and then a few windows ones too.
Devices are known my their public key known as their Device ID. One of mine looks like SDVXIU4-UFW7ZAK-CEWOLS4-ETX6KFX-6AHZDJC-Z36AJRD-G2PQIDM-FWUVXQ6
After two Devices are setup, you introduce them to each other. To do so you need some means of transferring the 64 char string from one device to the other. Mail, USB stick, chat, voice, QR code... use what you can make work
When the two devices know each other they can share a folder. Start by making a folder on one device and then select who you want to share it with.
You can easily share a folder with multiple devices, and they can then again share directly between them and a mesh start to form.
One interesting, but also a little dangerous, thing is the introducer. When Devices gets connected, they can be made introducers. That make them introduce other devices they know already. That way the mesh spreads easier, but also can make a giant mess if one is not careful with which device goes where.
« Last Edit: January 18, 2018, 03:44:55 PM by mogul »
MKS Gen L 1.0 by Bappi
[May 21, 2019, 07:22:54 PM]
ESP32 "Life is Life" 64x32 flexible P4 RGB LED by jinx
[May 18, 2019, 11:19:44 AM]
Warco HV-4" Rotary Table by jinx
[May 08, 2019, 03:12:58 PM]
Warco WM14 milling machine by jinx
[April 28, 2019, 09:41:40 AM]
MKS GEN L Servo Issue by Reywas
[April 22, 2019, 09:10:08 PM]
Re: Coding a Nano i2c Slave by AmandaG
Re: Servo Calibrator by Bajdi
Re: Servo Calibrator by jinx
[May 22, 2019, 02:28:13 AM]
Re: MKS Gen L 1.0 by Bappi
[May 21, 2019, 03:27:08 PM]
[May 21, 2019, 03:11:45 PM]
Servo Calibrator by BaldwinK
[May 21, 2019, 10:20:42 AM]
[May 21, 2019, 05:09:27 AM]
[May 21, 2019, 03:34:54 AM]
[May 21, 2019, 02:28:17 AM]
[May 20, 2019, 07:11:31 PM]
[May 20, 2019, 03:16:02 PM]
[May 20, 2019, 02:53:00 PM]
[May 20, 2019, 03:31:49 AM]
