Author Topic: Coding a Nano i2c Slave  (Read 408 times)
« on: October 25, 2017, 05:40:27 AM »
In a distributed system using intelligent leg modules and a central controller, each 4-motor leg module could be addressed as an i2c slave. The Nano is reasonably compact, has 18 usable I/O pins and is very cheap.
For earlier projects I used various PICAXE chips but needed higher mathematical capability.  Transitioning to the Arduino IDE I wrote master i2c bit banging code for a Nano as a learning exercise. It worked well enough to interface to IMU chips etc and to teach me to watch out for semicolons and double equals.
Of course the slave chips use hardware to detect fast edges and it is quite difficult to use software loops for the same effect. I had also missed the chapter on i2c in the Atmel datasheet because it is headed TWI.
It turns out writing code for an i2c slave is a lot easier using the Atmel registers.
Using the Hardware
First load the slave address (hex 50 say):
    TWAR = 0x50;                 //slave address to Atmel
Then turn on the hardware i2c function using the control register:
    TWCR = B01000100;            //set TWEA, enable Atmel i2c
    TWCR = TWCR | B10000000;     //hit the flag to get it going
Now wait for the status register to see what has occurred:
    while (!(TWCR & B10000000)); //wait flag to read status
Let’s assume the master is going to write (send data to us):
    if (TWSR == 0x60) {          //test status for addr + W found
                                 //the address found is in the data register
We hit the flag and wait for the first data byte:
    if (TWSR != 0x80)            //test status for data received ok
    goto error_handler;
    inbyte = TWDR;               //the first byte is in the data register
Continue as required. Obviously things are a little more complicated but the detail can be added once you get the idea. The Atmel datasheet is a must read and pay special attention to the protocol of Nacking the last byte.
Trimming the Protocol
My quadruped project has specific needs so the i2c protocol can be tailored to suit the need for speed etc.
Each of the four motors needs byte values for:
    Actual position in degrees  (read only)
    Next setpoint in degrees    (read/write)
    Current duty cycle 0 to 255 (read only)
    Maximum duty cycle 0 to 255 (read/write)
Driving the motors at twice normal voltage is good for torque but if a 50% duty cycle is exceeded for too long the motors or drivers will cook. This calculation needs a 64-byte fifo for a one second moving average of the PWM value. The motor power is removed for each period the maximum value is exceeded. It sounds like braking on gravel in a car fitted with an ABS system.
All data transfers will be four bytes long. Makes the thinking simpler.
The four parameters will not use a separate register address byte; the extra two bits can be a subset of the leg address.
Atmel got there first with the TWAMR bit-masking of the TWAR:
    TWAMR = 0x0C;                //mask out lower bits (Reg address)
So there is no switching from writing the register address, sending a restart, then reading the data bytes.  Whether reading or writing, transfers can be completed in less than 150uS.
Synchronising the Processes
Each slave Nano has to calculate four PID equations compensating for non-linear potentiometers, update duty cycle values, scale for each PWM and control the half bridges. This may take 12-13mS of the 15mS cycle time.  Keeping the cycle-time constant simplifies the calculus because the .dt elements can be removed.
Once its housekeeping is done, the slave will be ready to listen to the i2c bus. The master can then send or receive i2c instructions to each slave before the cycle restarts.
Neither process is interrupted but we do need to keep them meshing together.
The Atmel hardware can be configured for a ‘general call’ address 0x00.  The LSB of the TWAR register is set to enable the slave to respond to its own address and the general call address:
    TWAR = i2cadd | 0x01;        //slave address to Atmel, allow general call
Once the address is seen the slaves will start their own processes and will not listen to the i2c bus for a while:
    if (TWSR == 0x70)            //test status for general call
    goto house_keeping
The master is also free for a time to do its own thing.  Then when millis() counts out 13mS it must converse on the i2c bus. At 15mS it must send the general call address, finishing with a stop bit to keep everyone happy.
Antique (fun) stuff by MEgg
[April 24, 2018, 01:48:57 PM]
Spider by viswesh
[April 21, 2018, 09:41:33 AM]
Google Vision API using Raspberry Pi and Node by Ladvien
[April 20, 2018, 02:38:12 PM]
Hello from HITBOT - a young robot arm team by tinhead
[April 20, 2018, 11:32:57 AM]
MKS Gen L 1.0 by grayknight235
[April 20, 2018, 06:55:50 AM]
1B1 -- RAN Stack by Ladvien
[April 14, 2018, 10:40:54 AM]
Editing Raspberry Pi Code Remotely from Visual Studio Code by Ladvien
[April 14, 2018, 05:09:09 AM]
Post your last purchase. by Impala
[April 08, 2018, 12:54:11 PM]
Supercon by BaldwinK
[April 04, 2018, 09:57:55 AM]
Hex VI formally know as XCR3D v6 by jinx
[April 04, 2018, 07:10:51 AM]
Upload Arduino or AVR Programs to ATtiny84/85 Over UART by Ladvien
[April 02, 2018, 09:39:21 AM]
Are separate metric drill bit sizes sold in the US? by fabry
[April 01, 2018, 09:58:34 AM]
I2C Setup for Raspberry Pi Zero W with Arch Linux by Ladvien
[March 30, 2018, 09:35:16 PM]
Headless Arch Linux on Raspberry Pi Zero W by Ladvien
[March 30, 2018, 09:28:37 PM]
Sbase and the reprap full graphics smart controller by jinx
[March 30, 2018, 11:03:45 AM]
Re: Antique (fun) stuff by MEgg
Re: Spider by viswesh
Re: Spider by 1 what
[April 20, 2018, 10:38:41 PM]
[April 20, 2018, 01:26:35 PM]
Re: Hello from HITBOT - a young robot arm team by tinhead
Re: Antique (fun) stuff by Ladvien
[April 20, 2018, 06:58:52 AM]
Re: MKS Gen L 1.0 by grayknight235
Re: Antique (fun) stuff by jinx
[April 20, 2018, 04:25:26 AM]
[April 20, 2018, 02:13:52 AM]
[April 19, 2018, 08:03:25 PM]
Re: Antique (fun) stuff by Catalinaz
[April 19, 2018, 01:04:15 AM]
Re: Hello from HITBOT - a young robot arm team by Catalinaz
[April 19, 2018, 01:01:55 AM]
Re: Spider by erco
[April 17, 2018, 01:24:55 PM]
Re: MKS Gen L 1.0 by MEgg
[April 15, 2018, 07:47:32 AM]
