Author Topic: Which micro motor solution would be the strongest ?  (Read 517 times)
programer786
  • p
« on: June 07, 2017, 02:50:31 PM »
Hello,
I'm trying to make a project which needs really small but strong motors. They shouldn't cost to much as I'm trying to make this project as cheap as possible. If possible, I'd like to get them for less than 2$ per piece from China (I will need 5 of them).
The motors need to to rotate slowly (60 to 300 RPM). I found many small motors which fit those criterias but don't know which one is the strongest.
My first idea was to use these motors (which are still rather big) with PWM (using the PCB from an old SG90 servo), this made them rotate in the desired speed but not really accurately and I think they get weaker while using low speeds :
https://de.aliexpress.com/item/10PCS-Micro-130-pony-up-to-four-drive-dc-motor-small-motor-production-of-3V/32702094003.html?spm=2114.13010608.0.0.vTB33e
I also found some small DC motors with planetary gear boxes :
https://de.aliexpress.com/item/5pcs-DC-1-5V-3V-98RPM-Micro-10MM-Planetary-Gear-Reducer-Motor-for-Robot-Smart-Car/32782377317.html?spm=2114.13010208.99999999.282.EMgmie
https://de.aliexpress.com/item/5pcs-DC-3V-6V-Mini-10MM-Planetary-Gear-Reducer-Motor-Coreless-Motor-For-Robot-DIY/32777177278.html?spm=2114.13010208.99999999.279.EMgmie
Last I found some stepper motors :
https://de.aliexpress.com/item/5-Pcs-20MM-dc-6v-stepper-motor-with-gear-box-Double-flat-shaft-4-Phase-5/32330283301.html?spm=2114.13010208.99999999.289.EMgmie
https://de.aliexpress.com/item/5pcs-new-2-phase-4-wire-miniature-15MM-stepper-motor/32802792543.html?spm=2114.13010208.99999999.262.EMgmie
https://de.aliexpress.com/item/5pcs-NEW-6V-Precision-NMB-10mm-2-phase-4-wire-Stepper-motor/32770165992.html?spm=2114.13010208.99999999.269.EMgmie
I don't know whether the first stepper motor will fit the project because of the blue cable holder, but maybe I can remove it.
I will probably use some LM293 double H bridges to control the motors.
Could someone please tell me which motors would probably be the strongest ?
[Today at 05:23:38 PM]
All metal Titan Extruder by jinx
[Today at 04:24:23 AM]
UConduit H-Bot printer design by KingBeetle
[May 26, 2018, 02:10:38 PM]
MKS Gen L 1.0 by KingBeetle
[May 25, 2018, 12:49:36 PM]
Greetings! by KingBeetle
[May 25, 2018, 01:03:51 AM]
Hello Robot Rebels by jinx
[May 23, 2018, 04:40:15 PM]
Cardboard Bob by Pouserz
[May 23, 2018, 07:04:41 AM]
ChuckCrunch by Gareth
[May 23, 2018, 02:51:44 AM]
Sloth Robot=Bob by erco
[May 16, 2018, 02:17:07 PM]
URF to ERF by jinx
[May 07, 2018, 03:48:47 AM]
How pull-up resistors really work by maelh
[May 01, 2018, 03:39:13 PM]
Animabot - Advanced hexapod robot by Nemesis
[May 01, 2018, 05:53:03 AM]
Antique (fun) stuff by MEgg
[April 24, 2018, 01:48:57 PM]
Spider by viswesh
[April 21, 2018, 09:41:33 AM]
Google Vision API using Raspberry Pi and Node by Ladvien
[April 20, 2018, 02:38:12 PM]
Re: CZ-1 2.0: problems, calibration and printing, part2 by jinx
[Today at 05:08:52 PM]
3DBenchy boat by MEgg
[Today at 02:28:59 PM]
Re: All metal Titan Extruder by jinx
Re: All metal Titan Extruder by KingBeetle
[May 26, 2018, 11:32:04 AM]
Re: MKS Gen L 1.0 by KingBeetle
[May 25, 2018, 05:00:38 AM]
[May 25, 2018, 04:05:59 AM]
[May 25, 2018, 02:55:30 AM]
[May 25, 2018, 01:26:03 AM]
[May 24, 2018, 05:11:32 PM]
Re: Hello Robot Rebels by jinx
Re: Cardboard Bob by Pouserz
